Lucas wire color codes. https://www.landroverclub.com.ar/viewtopic.php?f=253&t=90288 |
Autor: | Cardte [ 20 Jun 2007, 18:21 ] |
Miren esta info que encontre! This table provides the standard Lucas wire colour codes used in Series Land Rovers (British Standard BS-AU7 determines colour coding of automobile wiring). I have added the Lucas codes for accessories that might be added to a series Land Rover, such as rear fog lamps, a rear window wiper and washer, driving lamps, radio and electric fan. Please note that Land Rovers built to military specifications use a different wire colour code. Black All ground connections Black/ Purple Temperature switch to warning light Black/ Green Relay to radiator fan motor Black/ Light green Brake switch Black/ Light green Brake differential pressure valve to warning light Blue Headlamp connections Blue Headlamp switch to dimmer switch Blue White Headlight high beams Blue/ White High beam dimmer switch to high beam indicator lamp Blue/ White Dimmer switch to long-range driving light switch Blue/ Red Headlight low beams Brown Main feed from the battery. No switches or fuses Brown/Yellow GEN to volt. Regulator Brown/ Blue power feed to headlamp switch Brown/ White Ammeter to main alternator terminal Brown/ Yellow Long-range driving light switch to lamp Brown/ Yellow Alternator to 'no charge' warning light Brown/ Purple Alternator Regulator feed Brown/ Green Fuse to horn (No relay) Brown/ Lt. Green Windscreen wiper motor to switch Brown/ Black Horn to horn button (no relay) Green Ignition switch controlled wiring for auxiliary devices, eg wipers, flashers, etc Green/ Black Fuel gauge to fuel tank unit Green/ Blue Water temperature gauge to temperature sender unit Green/ Brown Switch to reverse lamp Green/ Red Direction indicator switch to left-hand flasher lamps Green/ Purple Stop lamp switch to stop lamps Green/ White Direction indicator switch to right hand flasher lamps Green/ Yellow Heater switch to slow speed on heater motor or for single speed motor Green/ Gray Heater switch to high speed on heater motor Green/ Orange Low fuel level switch to warning light Light green voltage stabilizer to instruments Light green/ Black Windscreen washer switch to motor Light green/ Blue Flasher switch to left-hand flasher warning light Light green/ Brown Flasher switch to flasher unit Light green/ Purple Flasher unit to flasher warning light Light green/ Orange Rear window washer switch to motor Orange Wiper circuit Orange/ Black Wiper switch to to motor parking Orange/ Blue wiper switch to low speed on motor Orange/ Green Wiper switch to high speed on motor Orange/ Yellow Rear wiper switch to rear wiper motor Orange/ Light green switch to rear window motor parking Purple Accessories fed direct from battery via fuse (Always live) Purple/ Brown Horn fuse to horn relay when horn is fused separately Purple/ Red Switches to map light, under bonnet light, glove box light and boot lamp when fed direct from battery fuse Red Tail lights, instrument lights, parking lights and side markers Red/ Yellow Fog light switch to fog light or front fog light fuse to fog lights Red/ Blue Front fog light fuse to fog light switch Red/ Brown Rear fog guard switch to lamps Red Orange Power to rear fog guard lamp fuse Red/ White Fuse to instrument lamp switch, Instrument panel lamps White Ignition circuit, no additional switches, not fused White Power to coil White/ Black Ignition coil to distributor White/ Black Distributor side of coil to tech impulse sensor White/ Brown Oil pressure switch to warning light or gauge White/ Pink Ignition switch to radio fuse White/ Red Ignition switch or starter switch to starter solenoid Yellow Generator connections wired through the ignition switch Yellow/ Green Dynamo 'F' to control box 'F' Alternator field 'F' to control box 'F' Este es el link: http://www.expeditionlandrover.info/Lucaswirecode.htm Carlos Duarte Santana IIA 88" 1970 ![]() |
Autor: | Cardte [ 20 Jun 2007, 18:25 ] |
Que tal esta foto! ![]() Carlos Duarte Santana IIA 88" 1970 ![]() |
Autor: | OMAR [ 22 Jun 2007, 20:16 ] |
...LA ATROPELLÓ EL LANDY?? !! O M A R LAND ROVER SANTANA 88´S III ´79 S.V.O 300 218 5929 313 844 3288 ![]() ![]() |
