vendo cámara IP Pixord 207.
Incluye Lente y el mismo es removible. Se puede reemplazar por lentes de menor ó mayor distancia ó zoom motorizado. Tambien se le puede colocar lentes autoiris.
Ideal para vigilar a distancia casas ó comercios.
Precio: U$S 299.-
Estado: nuevo, en caja, sin uso.
Instalación: no incluye instalación, pero viene provisto con soporte y cables para conectarla. No incluye la fuente de alimentación 12v - 1amp (cuesta en comercios alrededor de $20)
Datos técnicos:
Supports remote recording
PiXORD-207 supports remote recording to a PC without installing any additional software. With just a single click, a video clip is recorded to the PC in standard AVI format.
Full screen monitoring
In addition to 3 different resolutions, PiXORD-207 supports full screen monitoring which makes the video larger, and easier to see what is happening in the monitored area without any un-related operation.
Highly compatible M-JPEG compression
PiXORD-207 uses Motion-JPEG compression to provide the most stable video quality. It is supported by many 3 rd party applications, which will fulfill the needs of time-to-market.
Multi-language support
PiXORD-207 is localized into many different languages.
Specifications
Hardware
System
Windows 2000 SP4 or Windows XP/Windows ME/Windows 98
Internet Explorer 6.0
DirectX 9.0c
CPU: 32 Bits RISC Processor
ROM: 2M Bytes Flash ROM
RAM: 16M Bytes SDRAM
WatchDog: Chip to monitor out tolerance system voltage and abnormal program execution
Connector
Two LEDs to indicate network and power/system status
One RJ-45 for Ethernet
One RS-232 serial port for external console
One RS-485 port for PTZ (pan/tilt/zoom) camera control
Four fully opto-isolated alarm inputs and one 3A, 125VAC/ 30VDC Relay output
Video Channel
CMOS VGA sensor
2.5 Lux (F1.4)
Network
Network Interface
Ethernet (10/100 Base-T)
Protocols
TCP/IP, UDP, ARP, ICMP, HTTP, FTP, Telnet, SMTP, DHCP
Performance
Network throughput: Max. Up to 800K bytes / sec.
30 connections simultaneously
Up to 30/ 25 fps
Video
Image Compression
JPEG; Motion JPEG
Video Adjustment
Brightness, Contrast, Hue, Saturation, Video quality, sharpness, backlight, flickerness and light condition adjustment
Resolutions
VGA: 640x480 QVGA: 320x240
Management
Function
Supports display rotation
Supports full screen display
Multi-Languages support
Event management
Programmable Event Scripting
Triggered:
1.Time (Frequency)
2.Sensor Input
3.Motion Detection
4.Video/ Network status
5.CGI trigger
Action:
1.Store image to internal buffer (2M Bytes pre and post-alarm)
2.FTP image to remote site
3.E-mail image to specific account
4.HTTP server push to remote site
5.Relay output to control external devices
6.Alert transmission to an HTTP listen server (for developers)
Installation
Using ARP & Ping or IP-Installer software to assign the IP address
Firmware Upgrade
Remote upgrade by FTP
Customized web UI is upgradeable via FTP and Telnet
Client PC Requirements
Standard browser such as Microsoft 5.x or above, running on Windows Me/ 2000/XP, Linux.
Security
Multi-tiered access control
Recording
Free 4-CH recording software
Operating Environment
Operating Temperature
5°C ~50°C (40°F ~ 125°F)
Input Voltage
DC 12V
Power Consumption
<10 watts
Mechanical Design
Dimension
135(L)*85(W)*40(H) mm
Net Weight
0.57 kg (excluding power adapter)
Accessories
CD Title with manual/software
Quick Installation Guide
Ethernet Cable
CS Ring adjust tool
Power Adapter
Stand for Desktop/Wall/Ceiling
One cable convert MiniDin to Dsub, to connect Com port or GPIO
