Aca esta el detalle de LAND ROVER MOBILE WELDING PLANT y otros accesorios muy interesantes.
http://www.rover.org.nz/manuals/landrov/land14.htm
LAND-ROVER MOBILE WELDING PLANT.
The Land-Rover, when converted into a mobile welding plant, can be fitted with both gas and electric welding equipment.
The Lincoln Shield Arc Junior" welding generator Is fitted on the centre-line of the vehicle, mounted partly in place of the centre seat and partly in the rear body compartment. It is driven from the centre power take-off by means of three Vee belts.
Fig. 58. Land-Rover welding plant.
Regulation of the engine speed during welding operations is effected in two ways. Whilst making a welding run, it is necessary for the engine speed to be constant and this requirement is satisfied by means of a standard engine governor. It is undesirable for the engine to run at this speed when not actually welding and an engine speed control is therefore fitted on the inlet manifold, to over-ride the governor under such conditions.
Generator voltage and current output can be varied independently, making the equipment suitable for welding all metals and alloys of any gauge.
Additional equipment such as electrodes, masks, etc., is carried in lockers provided over the rear wheel arches.
Apart from the normal maintenance necessary for any welding generator, the only attention required is periodic checking of the drive belt tension (see "CENTRE POWER TAKE-OFF").
In addition to the electric welding plant, gas welding equipment may also be incorporated. A bridge piece and ramps fitted across the tailboard enable the gas cylinders to be carried alongside the electric generator, while pressure gauges and other items are stored in the lockers and a separate carrying case.
Augusto. Discovery 300 Tdi
Buenos Aires, Argentina.
