Fecha actual 28 May 2024, 15:49
Mensaje sin leer Publicado: 09 Abr 2017, 14:51
Hola a todos y buen domingo !!! Por aqui en Mar del Plata lloviendo asi que me di una vuelta por el foro , y que mejor lugar que este para compartir nuestros jueguetes !!! Tratando de mejorar el Defe y ya que tenia que reparar el diferencial central , le dije a la patrona que me salia mas barato traerlo nuevo que arreglarlo , ustedes me sabran entender :roll:
Cuando lo tenga instalado les paso los comentarios .
Saludos para todos
A little background on the LT230 centre diff. The centre diff is there to allow the props to turn at different speeds when cornering to stop drivetrain wind up. The speed difference is quite small and the centre diff gears are only designed to cope with these low speeds. If you are Off Road on snow or ice and you get wheelspin from one front wheel, what will happen is the rear prop will not be moving, the front will thus be going double speed, this means the small centre diff gears will be spinning like fury and after a matter of only a few seconds the planet gears will friction weld to the cross pins and the gears will fail etc. Of course in this situation the centre diff should be locked to avoid failure.
There are instances when it's not convenient to keep the diff locked or to constantly lock and unlock the diff as the available traction dictates, i.e, when racing fast on a low traction surface, the vehicle will not handle well when locked but is likely to wheel spin when unlocked.
Another example of where the ATB would help would be when rapidly changing from high to low traction surfaces, i.e. when driving on snow or ice,
In both of these examples the ATB will limit the amount the difference in propshaft speed and transfer torque to the axle with traction.
The two big advantages are increased traction when unlocked and eliminating the weakness of the stock unlocked centre diff.
Note the ATB centre can still be locked like the stock unit when required, locking the diff is still advised when prolonged wheel spin is anticipated.
When an ATB is ordered to be built within a rebuilt LT230 the price will be reduced to £ 300.
We make 2 different types of these as there are 2 different diameters of spline used for the high/low selector hub, the one you need can be identified by either the serial number or vehicle type,
Type A - RRC, Disco 1, all Defender pre TD5, Serial numbers starting 20D, 22D, 25D, 26D, 28D, 29D, 36D
Type B - Disco 2, TD5 and TDCi Defenders, Serial numbers starting 41D, 42D, 43D, 57D, 60D, 61D, 62D, 68D, 69D, 70D
Note : Due to the nature of the ATB diff we do not recommend the vehicle is brake tested on rollers, ask for a decelerometer to be used instead.
Mensaje sin leer Publicado: 09 Abr 2017, 19:23
Muy bueno!! después contá como va y como se siente con ese diferencial central de deslizamiento limitado o ATB (Automatic Torque Bias)
Se tiene que destacar en calles/rutas de ripio sobretodo...
Abrazo,
Mensaje sin leer Publicado: 09 Abr 2017, 20:08
Hola Santiago !!! cuando regrese su medico de cabecera ( Gerardo Asselborn ) de su viaje entrara a terapia. Me ha llegado el intercooler doble nucleo y en el ya que estamos encargue el marco , el radiador y el turbo VNT de Allisport . La vida es una sola !!!
Ni bien lleguen todos los chiches subo las fotos !!!
Un abz
Mensaje sin leer Publicado: 09 Abr 2017, 20:17
gerardomdq escribiste:
Un abz
:grin: :grin: :bravo: :bravo: :bravo: :bravo:
Simplemente una compra espectacular.
Felicitaciones Gerardo!!
Mensaje sin leer Publicado: 09 Abr 2017, 20:30
Muchas gracias Pedro :grin: Al escribir en el foro recuerdo esa sensación que senti la primera vez que entre acá !!! Estaba buscando algun carromato viejo para ir a pescar , llevar los perros sin que la patrona se enoje por que le traia la camioneta con olor a pescado ,perro y osos por no decir a hombre sucio !!! Y pensaba esta gente esta totalmente enferma !!! Gracias a Dios me contagie asi que lo comparto con uds !!! Recuerdo tus palabras Pedro en el bosque de Pinamar... esto no se termina nunca :loco: :loco: :loco: Señal de que estamos vivos !!!
Un abz
Mensaje sin leer Publicado: 10 Abr 2017, 13:12
Hola Gerardo,
Te hago una consulta, la gente de Allisport te despacha todo tipo LRDirect?
Estoy en el mismo camino, intercooler y radiador uprated que se combinará con el TGV que ya tengo y bomba de 2.8.
Guillermo Pereyra
Mensaje sin leer Publicado: 10 Abr 2017, 16:48
Qué capo !!!!! le dije a la patrona que me salia mas barato traerlo nuevo que arreglarlo .... jajajajaja
In Glock we trust ..
Ex Discovery Blanca
Mensaje sin leer Publicado: 10 Abr 2017, 17:21
Hola Guillermo te envie MP
Un abz
Mi modelo Land Rover: Defender 110 SW County
Mensaje sin leer Publicado: 25 Jul 2017, 16:54
Hola Gerardo,
Te hago la misma consulta que Guillermo, la gente de Allisport te despacha todo tipo LRDirect? te cobran los derechos de importación y te lo entregan en domicilio.
Gracias.
Eduardo
Peugeot 504 GRII 1986
Defender 110 1996 County
Mensaje sin leer Publicado: 25 Jul 2017, 21:08
Hola Eduardo, este producto puntualmente lo tiene LRDirect . El codigo es DA9009 (Defender 300 tdi 1997, ver VIN de tu transfer). Los demas productos de Ashcroft me los ha traido un piloto de avion, como importador.
Cualquier duda estoy a tu disposicion.
Un abz
Mensaje sin leer Publicado: 25 Jul 2017, 22:51
y?? que tal su funcionamiento?
Mensaje sin leer Publicado: 26 Jul 2017, 00:06
Hermosisimo chiche!
Felicitaciones!
Mensaje sin leer Publicado: 26 Jul 2017, 00:25
El bicho valdría, puesto aquí por LRdirect unos 16300 mangos. ¿Costo estimado de MO de quitar e instalar el susodicho bicho? Así calculamos el costo total y vemos si la patrona podrá absorber el shock...ja ja ja
Mensaje sin leer Publicado: 26 Jul 2017, 00:42
Por ser vos por 7 mil te lo cambio :mrgreen:
Mensaje sin leer Publicado: 26 Jul 2017, 00:54
Ademas desde hace un rato aprendi como ajustar una tuerca y que no se afloje :-|
Mensaje sin leer Publicado: 26 Jul 2017, 11:09
O sea colocado, este accesorio, podría costar entre 25 y 30 lucas para un TDI ¿Tiene palo de amasar la patrona..? Guarda, confirmarlo antes por las dudas. No hay que correr riesgos innecesarios
Mensaje sin leer Publicado: 26 Jul 2017, 11:17
Defe90 escribiste:
No te enseñaron que cuando los adultos hablan los niños callan???
Guillermo Pereyra
Mensaje sin leer Publicado: 26 Jul 2017, 11:20
pikigrillo escribiste:
Piki aprendiste a aflojar una tuerca y que no se te ajuste???
Guillermo Pereyra
Mensaje sin leer Publicado: 27 Jul 2017, 00:11
Que avise che cuando gaste o intente gastar las 25-30 lucas en este diferencial que hace ciertas cosillas en un TDI si hay heridos por el palo de amasar...Les pido que tomen con humor lo que digo...
Mensaje sin leer Publicado: 27 Jul 2017, 09:24
Disculpen la ignorancia... Se como funciona un dife de deslizamiento limitado en la tracción trasera, pero desconozco que función cumpliría este dife central de Deslizamiento Limitado. Como se conjuga con el bloqueo manual de los diferenciales? Algún alma caritativa que me lo explique? Gracias
